Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatiehandleidingen en informatie over demontage voor de 12,9" iPad Pro (6e generatie) van Apple. Uitgebracht op 18 oktober 2022.
iPad won't turn on - battery may be broken
When I press the power button on the iPad nothing happens.
I followed the documentation from Apple[1] but that did not help.
My guess that the battery is broken and there is still warrenty on the device until 21-02-2025. There is no visible damage and we did not drop the iPad.
[1] https://support.apple.com/en-us/102642
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
No power issues could be caused by any number of things. They can actually be one of the more complex issues to troubleshoot due to the number of failures that could result in this issue. But my best advice is to take it to Apple if it's still under warranty.
This could be the battery, but based on the fact that the device is so new, I am not likely to think that's the issue. If you actually wanted more diagnostic information you would need a USB C ammeter/multimeter which could tell you how much energy the iPad is pulling from the charger.
Just out of curiosity, when you followed the page from Apple, did the PC detect the iPad was connected at all?
Was dit antwoord nuttig?
Score 1
Try doing a hard reset with the charger plugged into the device.you can do this by holding the power button down and volume down button hold it for about 15 seconds after 15 seconds press power button
Voeg je antwoord toe
Tobias Platen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 21
Altijd: 373
