Ga door naar hoofdinhoud
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
R. Hinge barrel won't slide out.
Trying to replace this hinge since the right (where the WiFi slider is) before having to pay someone or just buying a new unit all together. I'm at the step where you have to slide the barrel out (I've already taken out the mother board and stuff) and no matter how much force I use, and what angle I do, this barrel hinge does not want to budge. I've tried various tools and the smallest flatheads I had, and no luck. It's to the point that I damaged the spot where the slot is,. I've been at this for a while and I've looked at YouTube guides and some forums, but Im still stuck. I'm honestly just frustrated and I'm just about to buy a whole new 3DS XL.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi there!
This one is very difficult and need a lot of patience and time. Put some Isopropyl alcohol on it and see if the will ease things.
Otherwise you could also a repair shop to do it for you. I also have troubles with it sometimes, it's difficult...
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
I will to do this and see if i have any luck, Thank you.
door
so it did work for me, but i have to buy a new barrel hinge and LED Bit but that's not an issue. Now i can finally continue the repairing and transferring process. Thank you!
door
My pleasure! Good luck with the repair!! If there is anything else, please let us know :)!
door
Voeg je antwoord toe
IFixTT zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 128
