Fan not spinning after swap!
Recently, the fan on my thinkpad stopped working (I assume the bearings went out- it was making a horrible grinding noise for a bit before it died completely) I've ordered the exact same part and replaced it (image), as well as re-pasting for good measure. However, when I try and boot now, it still refuses to spin at all, and so I still get "fan error" which forces shutdown even if I'm trying to get into BIOS/press esc... I've tried resetting by unplugging the CMOS and fully depowering the motherboard a few times, but no cigar. I've also used a multi-meter to make sure that there wasn't a connection issue, and every wire going into the fan is connected to the correct motherboard out, with no overlap between them. The fan is the exact same model as far as I can tell, identical down to the wire colors/order and all the text on it. I haven't been able to really find any post be about this precise issue, though I know the fan error message in itself is common. Additionally- I got a strip of reflective/metal tape with the fan part, which seemed to match up with what the original had, so I applied it where I remember it being. Not sure if it's actually important but I assumed it was for grounding. Am I missing something obvious? Has anyone run into this before?
Is dit een goede vraag?
1 Opmerking
do you have a DC supply? could rule out the fan being broken but running the voltage through it and see if it spins up.
door Logixal
