Ga door naar hoofdinhoud
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
Top Screen pink tinted and flipped
I was cleaning the A button and had to take my 3DS XL apart multiple times, but now after disconnecting the top screen 3 or 4 times, it is now tinted pink and horizontally flipped. What do I do?
Is dit een goede vraag?
9 opmerkingen
Hi Jonathan!
Can you add some pictures for us, so we can check as well? Voeg afbeeldingen toe aan een bestaande vraag
It’s possible that the ribbon cable is damaged or not inserted correctly.
door
Hi koppie007 thanks for responding here are some pictures
door
Ok thank you! I’ll let you know!
door
Thanks! And good luck with the repair!
door
It worked! Thank You!
door
4 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi Jonathan!
Thanks for the pictures!
This do indicate that there is a problem with the flex cable… the only way to fix this is to replace the top screen.
Guide and part: Nintendo 3DS XL Upper LCD Display Replacement
Replacing this one is very difficult, but worth the try!
Please let us know how it goes!
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Jonathan Williams zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 27
Altijd: 335
