How to fix my horn in avantie 1996 (the fuse is not dammeged )
my horn sudenly stop warking and some times when i press it it goes but most of the time it is not and I check my fuse box and the copper inside the horn
Is dit een goede vraag?
Remove the horn and clean its electronic parts well with salt injector spray, and if your horn model has mechanical parts, grease it with grease or lithium soap-based oil, then install it. If the problem is not solved, it is possible that some electronic parts are damaged. Test and replace if possible
Was dit antwoord nuttig?
@asemwaleedm3799 please do not use any salt spray on the electronics. Don't use anything on it since you will not get to the internal horn parts. Check your wiring. Connect the horn briefly direct to your battery. Negative (-) will be on the horn housing and positive (+) on the contact where the wire connects. If your horn now makes a sound you know the horn is okay.
Since the error is intermittent, it could be the horn relay. Your Avante appears to be sold as teh Elantra over here. In that case the relay should be in the power distribution box under the hood in front of the battery. The horn relay is the 3rd relay back on the right side of the box if standing in front of the bumper right in the middle of the box. It is offset in line of the other relays and has a smaller relay behind it. Replace that relay and see if your horn now works.
If it still has the same issue, then the problem could be your horn switch. That will be the more difficult part since you will have to remove the airbag etc. Let us know and see your exact Hyundai model. Post some good pictures of the horn, the fuse box and the interior horn switch etc. with your Question. That way we can make sure that we have the same model ID and we can guide you further. Voeg afbeeldingen toe aan een bestaande vraag
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 28
Altijd: 104
