Ga door naar hoofdinhoud
Over ear Bluetooth headphones which have a magnetic switch on the right earpiece.
My right earpiece stopped working, no more sound
I have a Sennheiser pxc 550.
I wanted to use it, and realised one of the ear pieces wasn't making sounds. It's the right ear piece. I never connected it trough bluetooth to my laptop, so I was using the wire (the one that came with the headset) The wire goes in the right ear piece, if that matters.
I tried turning the headphones on and off. I connected the headphones trough bluetooth with my phone, still no sound from the right ear. I tried to reset my headphones next, witch didn't work either. I tested with another headphone both my laptop and phone, those work fine.
Does anyone know how to fix this?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi there,
I've got the same problem, right ear doesn't work without any incident / any hurt.
I've tried thousand things, update mobile app, change settings, reset using the app, try BT or Wire, at the end I was ready to open it !
Finally... I reset all the settings manually and it works ! I read that you already reset the settings but did you try to do it manually ?
(as it mentionned at the end of the user manual)
Resetting the headphones to the factory default settings/Reset
1. Switch the headphones off
2. Press the voice assistant button for 4 seconds (near the ANC button)
https://www.manualpdf.in/sennheiser/pxc-...
Hope it will help
Thanks
Was dit antwoord nuttig?
1 Opmerking:
Hi there, 2 months later same problem... this time reset process doesn't works, then I plugged via the mini jack cable to my computer (BT turned off) and it works again, then I turn on the BT and it's ok... ! I think it's a software trouble... the PXC doesn't like changes : to go on PC, then on smartphone, and comeback on PC with an external Audio interface ...
Good luck
door
Voeg je antwoord toe
Nadja Van Landeghem zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 93
