Ga door naar hoofdinhoud
A compact point-and-shoot camera with a rechargeable lithium battery and 12x zoom.
Is there any way to repair damage from overvoltage?
I have one of these cameras, and I tried testing it with the DC power plug it has on the side. I was unaware that the power supply I was using was way too high of a voltage for the camera, and now it won't turn on at all. Any way to fix this or is it a total loss? Thanks.
Update (12/18/24)
I’ve taken the boards apart from each other and carefully inspected both for any signs of scorching or heat damage. The only two chips on either board that look damaged are these two in the pic. Not sure if that’s repairable, I might have to just get a new camera.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@larata04 most likely a failed component. Either a diode or a DC-DC converter. Time to disassemble it and to take a look at the main board. Take a couple of pictures of the board and lets see if we can identify things that may have gone wrong. These guides should at least get you into the camera Minolta Dimage Xt
Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Voeg je antwoord toe
larata04 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 164
