Ga door naar hoofdinhoud
A color version of the Nintendo Game Boy, released in 1998. Repair of this device is straightforward.
One of my d-pad buttons isn't working
Down on the d-pad will not work. I have tried cleaning the contacts with alcohol and everything, and even got a new button kit (including the rubber things underneath the buttons that touch the contacts) and I still have the same problem.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
I had no idea what could cause your issue. So I turned to reddit. One user said:
"You might want to inspect the motherboard under magnification. Micro cracks may have appeared across the button traces. It's ironically caused by pressing too hard. They can be fixed by bridging the traces with solder and some fine wire."
Hope that helps!
Was dit antwoord nuttig?
Voeg je antwoord toe
x7universe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 23
