Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
2351 Vragen Bekijk alle
Where is the actual power ic? - Solved
i have had this similar problem, it took alot to repair though, i replaced the battery, charging dock and i reflowed the board, this worked for me, and where is the actual power ic?
Is dit een goede vraag?
Score 1
1 Opmerking
thank you alot, my friend, you are awesome, thanks to you got the repair done with and the customer was extremly pleased, thanks again
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Step 17 of this guide looks straight at the IC. It is labeled 338S0867.
Was dit antwoord nuttig?
Score 3
If you actually do need to replace this I.C. the cheapest place to buy a replacement from would be here.
Power Supply IC Chip For iPhone 4
Unless you are trained in replacing an I.C. I would recommend asking Hector Hector's Profile
He is a Guru at soldering.
Score 1
thank you too deano, your help was much appreciated, thanks again my friend
Voeg je antwoord toe
Krayzee zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 13,000
