Ga door naar hoofdinhoud
Repair and disassembly information for Samsung's Galaxy S22+ smartphone. Model number: SM-S906x
10 Vragen Bekijk alle
Can't access recovery menu
Hello,
I bought a Samsung galaxy s22+ from a (trustworthy) second hand store. Since I'm travelling, I let them send it to a friend. Said friend sent me the whole unboxing thing to show me if everything worked - and it did. Now the friend brought me my phone. I inserted my old sim cards and turned it on to set it up. But I ended up with a lock screen that asked for a pin code. I thought it was mine, since my sim cards were in it, but I could put in any numbers - it seems the 'OK' button doesn't do anything.
I also couldn't get it into recovery mode - it always ends up with the lock screen.
So I was recommended to let the battery drain, and try again. Just did that two times - still ending up in lock screen every time I hold the volume up and power button.
My friend didn't do anything with the settings, nor did they set a pin code.
My old phone is about to die, hence why I bought this solution.
Grateful for any ideas!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Well Checkout the following video it might help you in fixing the issue:
https://www.youtube.com/watch?v=G1m72Wxo...
Was dit antwoord nuttig?
1 Opmerking:
I tried it out, thank you. It was good to follow the instructions in the video. But it never goes into recovery mode - after the Samsung logo appears it jumps back into lock screen.
door
Voeg je antwoord toe
m s zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 19
