Why won't my washer go into diagnostic mode?
My washer filled with water at the end of the spin cycle and then the red "done" light came on and the lid unlocked. I could not get it to run the "drain & spin" cycle or reset and run any other cycle, the green sensing light will come on and then it flashes green and then goes off. So I had to empty the water out manually. I have tried unplugging and putting into diagnostic mode but that won't work either. It just constantly makes a whirring/humming noise and then stops, then makes the noises again and then stops. Anyone else have this issue. Also, I did put it on its back and checked the drain hose was not clogged and the belt is good. A parts website recommended a new shift actuator but I am not sure that is it???
Is dit een goede vraag?
