Ga door naar hoofdinhoud
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
3DS xl Blue light and Green light no screen/not booting but backlight
So I took apart a 3ds xl to clean it because it smelled like cigarettes, I managed to clean and when I put it back together it didn't work I tried to go into safe mode and the blue light and green light turn on but the screen wont and the backlight turned on. So I took it apart again reconnected all the ribbon cables again and I turned it on without screwing anything and I just hold the battery in place, it turned on so I screw it back together and it didn't work again, so I dissembled it again did all the same things I did the first time and tried turning it on without screwing anything in and just hold the battery in place but it didn't turn on just blue light and only the backlight of the screens were on. What do I do? And what could be causing this?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi Hugo!
Please tripple check all the ribbon cables. Also check if they are damaged or not. It’s possible that the WiFi chip isn’t seated correctly. Also check that one. Do you also hear a “pop” sound?
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
No popping sound, will now recheck all connections
door
Glad that you solved it!! Have fun gaming :)
door
FIXED Reconnect all the ribbon cables and now its working
1 Opmerking:
Glad that it’s solved :)!!
door
Voeg je antwoord toe
Hugo Dantas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 107
