Ga door naar hoofdinhoud
The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
Why does my GameCube’s power light flash once?
So my GameCube started rapidly resetting, so I turned it off. When I turned it on again, the fan would spin and the orange light would flash but nothing else would happen. What do I do?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
So I figured it out. If anyone else ever has this issue, it's the power board. I replaced mine with another and the GameCube's working with no issues at all.
Was dit antwoord nuttig?
1 Opmerking:
Good to hear that you got it solved!! Have a nice day!!
door
Het nuttigste antwoord
Hi!
First take the top cover off, so that the buttons (power and reset) are free. Then try to turn it on again. Is it still resetting it self? Try to replace the front panel and try again. Could also be power button related OR power supply related.
Score 2
8 opmerkingen:
I don’t know if it still resets, because it won’t turn on. The orange light flashes once and the fan spins but nothing else
door
Okay, then I recommend to replace the power supply first! If that didn't worked, then please replace the front panel!
door
@dan0 front panel as in the controller panel?
door
Yes! Probably one of these 2 are faulty!
door
I've tried a new external power supply, but I have not tried a new controller panel. I removed the one I have and it still didn't turn on, is that normal?
door
3 commentaren meer tonen
Voeg je antwoord toe
Deacon Ollis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 36
Altijd: 759
