Ga door naar hoofdinhoud
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
Housing/ stand compatible with 2009 iMac?
I previously had a 2009 imac, which the display randomly broke on it giving me grey screen no matter what. I have now purchased a 2010 iMac which has a broken stand. is it possible to swap the housings and/or stand between the 2? also i assume that my ssd from the 2009 is just plug in and works right? or do i need to do extra work?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It’s a far amount of work to get to the hinge which is inside the housing. Even still that’s what I would do.
As far as your SSD that should be fine. Depending on what the new system has for RAM I would boost it to 16GB while in there.
Basically, just follow this guide as the foot hinge is just behind it iMac Intel 21.5" EMC 2389 Logic Board Replacement
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Sam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 69
