Ga door naar hoofdinhoud
Microsoft's derde generatie Xbox game console, uitgegeven op 22 November 2013.
My Xbox turns off and on constantly. Does anyone know a solution.
I had to seriously unplug it it's not reacting to touch the button is powering its self on and off we wipped down the button area with a disinfected cloth it and its still being weird.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi Jennifer!
This is common with Xbox One Originals!
And it’s 9 of the 10 times, the front board it’s flex cable in this case.
Replacing this should fix it! The problem is most of the time in the cable and thus you can replace the sensor cable OR replace the plastic front panel with the cable already in it.
I recommend to buy the plastic front panel with the sensor ribbon cable already in it. This is easier for the repair and saves a lot of headache.
Part: https://www.ebay.co.uk/itm/182062517403?...
The complete part (plastic front panel with cable already in it): https://www.ebay.co.uk/itm/186564331467?...
If you need an manual or anything, just let me know!
Was dit antwoord nuttig?
Score 2
6 opmerkingen:
How hard is it to replace the cable. I hate to replace the entire panel cause it's a halo 4 addition
door
BTW would love the manuel
door
And thank you do much!
door
@jennifergr63659 it’s pretty okay to do so! The only somewhat difficult part is the white rubber where the Xbox logo is. Here is a guide: https://youtu.be/2o37qjXIx0o?si=Uj8IbkJg...
My pleasure and good luck!!
door
Thank you Koppie! Turns out when we took it apart to look. A sweet little 2 year old fed the xbox a Hostest powdered raspberry donut. Once we got that cleaned out. It worked perfectly fine but. We would not have found it without your help
door
1 commentaar meer tonen
Voeg je antwoord toe
Jennifer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 121
