Ga door naar hoofdinhoud
Head won’t go up or down, sounds like it’s trying.
Head of the bed won’t go up or down.
Is dit een goede vraag?
Score 2
3 opmerkingen
Ensure that the lock feature isn't engaged, which can prevent movement. Some beds have a "lock" or "hold" feature to prevent accidental adjustments.
door
f the bed's head movement is powered by motors, check for any obvious signs of malfunction, such as strange noises or lack of movement.
Listen for sounds of the motor trying to engage. If you hear a buzzing sound but no movement, the motor might be faulty or the mechanism could be jammed.
Inspect the motor and mechanism for any visible obstruction or damage.
4. Hydraulic or Pneumatic Systems
If the bed uses hydraulics or pneumatics to adjust the head, check for fluid leaks or damage to the hydraulic pump. Low fluid levels or air in the lines can prevent movement.
For pneumatic systems, ensure that there is no air leakage.
5. Check the Cables and Connections
Ensure that all cables and connections, including those leading to the control unit or motor, are properly connected and not damaged.
6. Reset the Bed
Some Stryker beds have a reset function. Check the manual to see if there’s a way to reset the bed's control system or to troubleshoot with diagnostic codes.
door
Please take this advice with a grain of salt; it is obviously AI-generated and hasn't been checked for accuracy.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
chances are that one of the gears is stripped or the motor isn't getting enough torque due to a lack of power.
Was dit antwoord nuttig?
Score 2
the CPR isolator is strip out because it just plastic, you have to remove the fowler to get to it.
Voeg je antwoord toe
cjwhereatt@yahoo.com zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 41
Altijd: 658
