Ga door naar hoofdinhoud
De HP ProBook 640 G1 is een laptop die in 2014 werd uitgebracht. De laptop bevat 4e generatie Intel Core-processors, een 14-inch ontspiegeld beeldscherm en diverse beveiligings- en connectiviteitsopties.
Why is hp probook 640 G1 blinking
My laptop is blinking every 1 or 2 Second and screen turn into black and stop working then again normal can i fix it
Is dit een goede vraag?
Score 2
3 opmerkingen
Hi, what is blinking exactly the screen or a light near the keyboard. A short video of the issue or a picture would be useful to help diagnose it.
door
Screen is blinking for 1,2 seconds and become totally black but curser es moving in black screen
door
Complete screen turn into black but pointer is active
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Good morning, I am a Windows System administrator and problems similar to this happen fairly commonly in my experience.
Please try the following.
Press the "Windows Key" + "R" at the same time, once the run pop up appears, type "explorer.exe" does anything change?
Alternatively, press "Ctrl" + "Shift" + "Esc" to start task manager, find "windows explorer" under tasks and restart it, If you do not see "Windows explorer" click on "Run new task" and type in "Windows explorer"
Its not impossible for this to be a display driver issue as well but we can explore further into that if the above does not change anything.
 V/R
Lucas
edit, deleted and reposted answer using my preferred account
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Yes I thought it might be a software issue so I didn’t reply .
door
Hi
Try removing the RAM, gently cleaning the area, and then reinserting it.
Voeg je antwoord toe
Adnan kamal zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 29
Altijd: 424
