Ga door naar hoofdinhoud
Apple's top-of-the-line smartphone for 2020. Announced on October 13th and released November 13th, the iPhone 12 Pro Max sports a 6.7" OLED display, a triple rear camera system with LiDAR, and 5G connectivity. Successor to the iPhone 11 Pro Max.
Forgot to disconnect battery during screen replacement
I repaired the screen of a iphone 12 pro max, I forgot to unplug the battery and now it will not turn on whatsoever. No sign of life. Is there any solutions to this?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
In cases where there are "no signs of life" I always try a few things.
  1. Connect to a computer. Is it detected in any way? Check File Explorer, Device manager or Disk manager on a Windows machine if it doesn't show in iTunes. Use Finder, Disk Utility, or System Info on a Mac. This could mean it IS just a display issue.
  2. Connect to a USB ammeter/multimeter. The amount of power the phone is consuming can tell you a lot. It is a way of getting a read on behavior based on
  3. Check with the old screen. It's possible the new screen is the issue. Or see if it powers on with no screen attached.
If it is truthfully not powering up, chances are the logic board was damaged during the repair. The battery remaining connected opens the possibility for circuits to be inadvertently bridged when power is running through them. This commonly happens when parts are connected or disconnected. Or if metal tools are used during the repair and it slips.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Turns out the phone's battery was just dead. How embarrassing
door
@kenny44422 Hey, I would take that as a win. Glad it was just that. :)
door
Voeg je antwoord toe
Kenny zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 173
