The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering.
284 Vragen Bekijk alle
brand new digitizer but touch part doesnt work
I have a brand new digitizer and i used it on a corrupted iPhone and it work working perfectly fine and i out it on another one that was working fine with broken glass. i replaced it with this new digitizer and the picture shows up but i cant unlock it
any help why this is happening or like maybe i dont have the ribbon cable in
can some one tell me which each cable does?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ooit iets gerepareerd? Je bent een genie.
Deel je reparatie met #ImAGenius
We zijn allemaal genieën
4 Antwoorden
Gekozen oplossing
try reseating all the display connectors first-they can be tricky, make sure phone is powered off before attempting this or you may end up with more problems.
Was dit antwoord nuttig?
it is an apple software problem and not a hardware issue
Software problem ? Mine worked with the broken display, but after I replaced it with the new one the touch screen didnt work anymore
I go for hardware issue, but you never know. Sure you can and should try to do a hard reset on your phone after repair like this. Sync your iPhone then put it into dfu mode, restore it and then just re sync it with the old sync. See if that fixes it,When you have done that and it still does not work I would make sure that all the connections are seated properly and that there is no corrosion or debris on the connectors. Let us know how it is going ....good luck
Voeg je antwoord toe
andrew zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 2,382
