What could cause just one of my coil packs not to get power
Only one coil pack is not getting power coil pack is new and I’ve tested it by moving it over to other plug I’ve checked fuses and cleaned terminals
Is dit een goede vraag?
Score
0
Hi, by moving the coil pack to another plug you got it to work or it was still faulty? If the coil pack is faulty then moving it to different plugs will have no effect, if the plugs are bad then whatever coil pack is attached to it will not function. sorry if im not understanding your problem.
door Robust
I moved the coil pack to a different spot and it works and gets spark and I put the new Back where it was and still cannot get spark or power at all The other two get power tho
door Jordan Bedway
