Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
Battery wont charge after battery replacement
My battery replacement arrived today and i follow the instruction to replace the battery. I have ensure that every ribbon has been connected and has double check before putting it back together. The phone would turn on and show a low battery screen. I try restoring the iphone but that didnt help. The phone would not charge at all. I try to plug it in a different computer and it still wont charge. Any help?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You may have just received a bad battery. Take out the new one and replace it with the original and see if it does the same thing. If it doesn't then you can pretty much assume you received a defective battery. It happens all the time.
Was dit antwoord nuttig?
Voeg je antwoord toe
sor2y zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 876
