My xbox won't output the image
Is dit een goede vraag?
If your Xbox isn't outputting an image, here are some troubleshooting steps you can try:
1. Check Connections: Ensure that both your TV and Xbox are powered on and that the HDMI cable is securely connected to both the TV and the Xbox. Make sure the HDMI cable is plugged into the "out to TV" port on the console.
2. Correct Input Signal: Verify that your TV is set to the correct HDMI input signal.
3. Power Cycle: Turn off your Xbox by holding the power button for 10 seconds, then turn it back on.
4. Reset Display Settings:
• If there's a disc in the console, eject it.
• Press and hold the Power button on the front of the console for 10 seconds to turn off the console.
• Press and hold the Power button and the Eject button until you hear a beep to turn on the console. You’ll hear one beep right away and a second beep 10 seconds later. The power light will flash on before the second beep. Don’t let go until you hear the second beep or see the console start up in low-resolution mode.
If these steps don't resolve the issue, it might be necessary to contact Xbox support for further assistance.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 156
