Ga door naar hoofdinhoud
The second generation was introduced as a 2003 model at the 2002 Chicago Auto Show, based on the new Impreza platform, featuring several fine-tune improvements over the past model.
11 Vragen Bekijk alle
Why water is not coming for front windshields?Subaru forester 2005
Is the windshields water pump that stopped because the water was emptied ?how to fix it?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@noraer check the hoses that go to the windshield washer nozzles for any blockage, kinks or even holes. Disconnect one of them and activate the washer. You should hear/feel the pump on the reservoir working. If water does come out of the disconnected hose, you may need new nozzles.
If not, then check for power on the pump. Use a test light or a voltmeter and test it when your activate the washer pump. If you have power going to the pump then it is the pump that needs to be replaced.connectors. Of course check fuse #15 in the fusebox. Here is the wiring diagram for your Forester Subaru Forrester Wiper Washer System
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Noraer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 39
