Blown Component on motherboard
Hi,
I have a PS3 which turns on but get no display on the screen, its not yellow light/red light or anything. Its as if the video cable or hdmi isnt connected. I have stripped down the console to look for damage and there is a broken component on the motherboard, except I dont know what its called and therefor cant look to buy a new 1, I also dont have a donor board to use. I have included an image for you to see and on the top of the part it says '3R9'. Please can anyone tell me what it is?
Thanks
Is dit een goede vraag?
6 opmerkingen
it's a 3B9 chip
door Nick
3B9 coil olturkey03
door Nick
Do you have any markings for that coil on the logic board, should be a L something That way I can identify the values of the coil.
door oldturkey03
Go to Mouser and Newark Electronics, run the numbers on the coil through their search. If that does not pan out, look at the traces coming off of it. Do they share common points and/or lead to the same place as the capacitor mounted next to it? If they do, it is most likely part of a tank circuit - possibly for a ground. Get the value off the cap, then do the math on what the value of the coil/inductor should be in a tank circuit. That will give you the value of the coil, if such is the case.
door ABCellars
Thanks for all the help everyone, I may be able to get a donor board for it after all, i'll see how it goes and post results, i saw this http://uk.mouser.com/ProductDetail/Panas... on the shops ABCellars recommended (thanks for that) which is the closest thing to it but still not quite the same. I now beleive the correct name for the component is an inductor, correct me if im wrong.
thanks again and ill let you know how the transplant goes in the next few days
door Aaron Marsh
1 commentaar meer tonen
