Why does my iMac G5 not power up after logic board exchange?
Hello
I exchanged my Logic Board in this computer now it will not start up.
The old board had a couple bad capacitors and the computer would sometimes start and run for awhile before freezing up.
I have checked the LED's and the # 1 light is on when plugged in.
When I hit the power button the # 2 light comes on, the chime sounds and then the # 4 light comes on, red color, and the computer powers down. The # 2 light goes out and the # 4 light stays on.
I can get the # 4 light to go out by bumping the power button but when I try to start up again the same thing happens.
Checked my power supply and it has a small burnt spot in the upper left part of the lower right quadrant and a white foaming looking substance on the board. Not sure if this is why it is not powering up because of the # 4 light coming on.
In all the research I have done I have not come across this issue so not sure what is going on.
So my questions are;
Why is the # 4 light coming on while the computer is starting up?
Is this why it is shutting down?
What is causing this issue and how do I fix it?
Or is it all tied to the power supply?
Any advice would be very much appreciated and thank you in advance.
Randy
Is dit een goede vraag?
