Ga door naar hoofdinhoud
Get essential information you need to repair your HP Chromebook x360 14a-ca0000 series convertible laptop yourself. Here you can find repair guides, manuals, troubleshooting and fixing help as well as many other useful resources for HP Chromebook x360 14a.
How do I replace Hinges on HP Chromebook x360, model 14a-ca0036nr
I want to confirm the required screen hinge part number for an HP Chromebook 360, 14a-ca0036nr. I was looking for a video or tutorial on to replace the hinges. If I can't find one, I may try to post a video when I try this Hinge replacement on a HP Chromebook x360, model 14a-ca0036nr.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @brenick19097
Here's the maintenance and service guide for the HP Chromebook x360 14a-ca0000 series, that should be applicable to your model as well.
Go to p.37 to view the procedure to remove/replace the display assembly. This will allow you to see how to remove the hinges.
The hinge part number (see Item #11 on p.15) is M15311-001. Search online for the part number only to find suppliers that suit you best. Just to verify the part number, it is the same number as shown in the parts list for your exact model.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
brenick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 173
