Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
20 Vragen Bekijk alle
DVD is inserting but it's giving it back
Hi, I have a problem with my macbook. The problem is that when I put CD/DVD it's get injected but the system gives it out. I tried System Diagnostic, PRAM and NVRAM. I don't know what to do about it. But the wierd question is it worked in boot order before i Install MacOS Catalina and After that I Installed Open Core Legacy Pather and it's not working. Can you help? Thank you.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Likely the optical lens is dirty, use a CD/DVD head cleaner.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Ok I bought the DVD/CD Cleaner that I put to the Mac and I will get you update if it works or not. And Thank you for Replying. :D
door
That's wierd. Beacus when I put the cd Cleaner it got stuck but that's not the problem beacus i got it back. But the problem is that the CD cleaner got accepted but my CD does the same thing.
door
@vojtechvapenik - Are you sure it’s a good disk? Clean and no scratches? And lastly a valid disk type. Try a music CD or a regular DVD movie (not blue ray)
door
Yeah I tried the disk with Windows 10 install media that is DVD RW I think And I tried a blank CD and not worked and I didn't see on both CD/DVD scratches and clean as a Fresh Water. So I orderet a Led Indicator and I'm gonna replace the disk with a dual disk so I'm gonna have 2 disk. I will try to use this as a external disk but i dont know right now. I will at least try. Thank you @anj for helping and have a good night :D
door
Voeg je antwoord toe
Vojtěch Vápeník zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 63
