Ga door naar hoofdinhoud
Hier vind je informatie over reparatie, demontage en probleemoplossing voor de Steam Deck OLED, een heruitgave uit 2023 van de populaire draagbare spelconsole gemaakt door Valve. Uitgebracht op 16 november 2023. Te identificeren met modelnummer 1030.
Power light pulsing, won't turn on
Hey all,
Got a Deck OLED, & charged it up for a few hours. It turned on & got to the initialization screen, & I powered it off. I took the 2tb SSD out of my old Steam Deck & put it in the new OLED Deck, along with swapping the back plastic with a JSAUX perforated backplate. Both worked perfectly fine with the old LCD Steam Deck.
I am very, very careful when modding devices, & was just as careful with this. After formatting the 2tb SSD & putting it and the backplate on the OLED Deck, the power button light just gently "pulses" for a few seconds, then turns off & nothing happens. Tried holding the power button for 3 seconds, 7 seconds, 16 seconds, 30 seconds, trying to put it in recovery mode by holding volume down & power, but if I hold the power button it will show the pulsing light for a few seconds, turn off, the indicator light will flash solid white once, then cycle between the two over & over. If I connect the Deck to power, the indicator light will stay solid green.
I took the back off, disconnected the battery, & tried plugging the deck into power with the battery disconnected. Instead of green, the indication light stays solid white, & if I press the power button, it just does the "pulse for a few seconds & then stops" thing same as before, but instead goes back to a solid white light.
I tried using the original 1tb SSD the OLED Deck shipped with, no luck. I tried the 512gb drive that was in my old LCD Steam Deck, no luck either. Same as my 2tb Sabrent SSD. It just pulses white when I push the power button no matter what I do.
It worked just fine before, I was insanely careful, just swapping the SSD & backplate couldn't have possibly bricked it. That's insane. Any ideas or thoughts? I really, really, really hate to need to possibly RMA it to Valve, it's gotta be something stupid.
Thanks & sorry for the novel
Is dit een goede vraag?
Score 1
1 Opmerking
Hi! I have this problem too, but I unplug the battery and it still blinks the LCD while I'm charging, I need some help.
Is always doing this stupid white blinking, I change the charger to a new one official, and nothing.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Well, seems like IFixIt may be a good luck charm lmao
Immediately after posting this, the deck decided to POST and give me a boot screen. It went into a few boot loops, and I gave myself a new hurdle to clear by using a bad SteamOS image install USB to reformat, but it was a pretty easy & harmless fix.
I would say what seemed to solve things was using the "correct" power cable - I have an old LCD Steam Deck, which uses the same 45 watt usb-c charger as the OLED model. I don't know if the voltage & amperage is the same on the transformer, though. I was using one of those old ones, since I figured it was exactly the same as the new one. I also have a UGreen USB power hub thing that provides PD power & plenty of watts (more than 45w), but I guess there's something about the Deck that's picky & it needing the exact correct power to work. It's weird. I plugged in the power block that came with the OLED Deck, & it cycled into a POST screen after a few minutes.
Anyway, if you're having issues - make sure to use the "official" power brick from Valve that came with "your" Steam Deck. That seemed to be, I think, what solved it for me. Probably. I hope. Maybe?
Hope this helps anyone else stressing out & suffering, thinking they have a Valve Steam Brick lol
Was dit antwoord nuttig?
Score 4
5 opmerkingen:
I'm having this exact issue. However I have not been as lucky to have it just randomly start working. I'm stumped guess its RMA time on a device that ive had less than 24 hours.
door
Using the original charger fixed my LCD steam deck, thanks for posting! 😁
door
Had the exact same issue. Using the official charger for a day made the SteamDeck OLED work fine
door
Your battery is dead, and you're using a low-power charger. Use a 45w charger and leave it for a minute.
door
I'm having this issue but my original charger broke, is there any alternatives ?!?
door
Voeg je antwoord toe
RLint zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 82
Afgelopen 30 dagen: 491
Altijd: 36,371
