How do I test new LCD installed in iMac g5 20"?
I took my mac to an apple store and they told me that the screen was shot. purchased a new LCD 20" screen and installed but image is still not coming. Any suggestions ?
Is dit een goede vraag?
did you check the RAM first?
if your imac having display problem after minor troubleshooting assessment i think your problem is in the logic board, the gpu chip. i recommended let the tech guy to do a re-balling the gpu/bga chip not just reheating using heat gun, or if you want to do a test you can use a heat gun to your gpu, just heat 10sec to the gpu chip and try to test, if you have the display probably it was bga problem
Was dit antwoord nuttig?
Thank you I will need your guidance on this one, i tried starting the comp holding down
cmd+option+p+r , i tried as well holding down the c key.
what suggestions do you have?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 507
