Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatie- en demontage-informatie voor de 12.9" iPad Pro van de vijfde generatie, uitgerust met Apple's M1 SoC en een XDR mini-led-display. Uitgebracht in mei 2021.
Screen is intact, but doesn't respond to touch - what to replace?
The touch feature on my iPad isn't working, but the screen is completely intact. What would need to be replaced to make it work again? Thx!
Is dit een goede vraag?
Score 2
1 Opmerking
Apple just said can’t repairs. It’s older now also
door Deel
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Hi Eric,
There are several points of failure where the digitizer can break down with no visible damage to the screen itself, and that sounds like what has happened to you.
Your particular iPad has the front glass / digitizer / LED display all fused into a single piece, so even though your glass and LEDs are all intact and working, it's not feasible for us average joes to physically separate them then refuse them back into a single unit. In short, you're going to have to replace the whole screen to get the digitizer (touch screen) working again.
It might be worth your while to check the connectors, but frankly I've never seen an Apple product fail because of a loose connector - they're just too well screwed down to be able to work themselves loose.
Anyway, here's the iFixit guide giving you step by step directions on how to do the job.
iPad Pro 12.9" 5th Gen Screen Replacement - iFixit Repair Guide
You can find replacement parts on all the major sites like Amazon, eBay and AliExpress and a host of others as well. They're still a bit pricey, but if you can wait a bit to ship from China you can get a fairly good price from AliExpress.
For iPad Pro 12.9 5th Gen A2378 A2379 A2461 A2462 LCD Display Touch Screen Digitizer Assembly Repair Parts 100% Tested - AliExpress
This, of course, assumes you've exhausted the software solutions like doing a backup then restoring the iPad to factory settings to see if that changes anything.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Sorry for the late response. But thank you for the excellent response!
door Deel
My apple IOS 12.5 stopped working abruptly a few years ago. All I see on the screen is the picture of the cord. Apple told me it can’t be repaired. All the information I had on it should be gone. Correct.
Voeg je antwoord toe
Eric zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 53
Altijd: 1,360
