Topcase - superdrive side: how can I make it fit more flush?
Hello. I've got a Macboook A1181, last numbers RVMN.
I got a new topcase installed, but I couldn't make it flush over the DVD, and sometimes the DVD came out "spotted", with dark splotches on the top part them. Not scratches: passing with the finger, I could clean them.
I tried removing the yellow pieces of duct tape in the small "protusion" that should enter in the grey pieces over the DVD bezel... but I fear I did something really wrong.
Have I? Any idea to make it more flush?
Is dit een goede vraag?
4 opmerkingen
I'll bring back to my friend with all the snazzy instruments on monday and I'll move the superdrive. Thank you. With the topcase slightly unscrewed it works better, despite the bulge. So, there must be something making the laptop "bloated" and pushing the case around.
door Stefano Gigante
Done! After I had, with the help of a tech, the Superdrive reseated, the topcase matched exactly the bottom case.
Then, it spit out a small piece of the textile (i can see a small gap by now...), and now it's working fine and peachy.
I guess it can be considered solved, can't it?
Good work, bravo !!
door lemerise
I opened another question, because now my Superdrive act up only when I use a certain, concave, "bowlshaped" cooling pad.
With a flat one, it's perfect. I guess the bottom case just hates being deformed.
But well, the "bravo" goes to you and ReMac. I wouldn't ever be able to fix something like that alone.
