Ga door naar hoofdinhoud
This generation of Suzuki Alto became widely available in 2009. This generation shares many features with its sister cars the Mazda Carol and the Nissan Pixo.
10 Vragen Bekijk alle
Break padel gone very low
Break padel is very down position when breaking
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@nitinjoshi check your brake lines for any leaks. Check your brake pads for wear and install new pads. Check your wheel cylinders for any leaks and if they may have seized. Check your brake fluid level and bleed your brakes. That should restore your brakes. If you have never done it, make sure that you get the right person/guide to help you with this. Brakes are kind of important for you and everybody else on the road. Let us know if you need more specific help.
Was dit antwoord nuttig?
Voeg je antwoord toe
NITIN JOSHI zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 19
