Ga door naar hoofdinhoud
Uitgebracht op 26 oktober 2018. Modellen A1984, A2105, A2105, A2106, A2108. Verkrijgbaar als GSM of CDMA / eSIM, nano-SIM of dual-SIM / 64, 128, of 256 GB / Zwart, Wit, Blauw, Geel, Koraal of Rood. (Uitgesproken "iPhone 10 R.")
20 Vragen Bekijk alle
Apple Pay Doesn't Work
I bought a 2nd hand iPhone XR from someone I knew who had owned it from new. It was a temporary phone while my iPhone 11 was being repaired. Unfortunately, Apple Pay didn't work. I tried a separate NFC tag and still nothing. I ordered a replacement part as per the images shown (not the charging coil, the small little flexi circuit that runs up close to rear-facing camera) and still it does not work. Is there an on-board component that could be faulty?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
It sounds like you replaced the wifi flex and not the NFC flex. Check for corrosion or damaged flex cables around the Wireless NFC Charging Flex and connector on the motherboard sometimes the foam around the connector gets in the way of the pins. It's an inexpensive part so I would just replace it. If that doesn't fix it then your NFC IC chip on the motherboard is probably fried. It's very common for the NFC charging flex to get damaged during back glass repairs so I would bet on that being the issue.
Was dit antwoord nuttig?
Voeg je antwoord toe
Chris Halliwell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 8
Altijd: 90
