Ga door naar hoofdinhoud
Released on September 24th 2021, the iPhone 13 mini is a smaller version of Apple's iPhone 13 and is the second mini iPhone. It features a 5.4-inch OLED, an A15 Bionic processor, and dual rear cameras.
Why is screen not going on flush
Screen not laying flat on phone
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Are you working on the phone and it's not going back together correctly, or did the screen just start separating on its own? Has anything happened to the phone recently such as being dropped?
If it's the former you'll probably need to add some pictures so we can see what's going on with your phone since there's no way we can tell what's wrong just from your description.
If the screen is coming off by itself, the first thing to suspect is the battery; if it's swelling that can push the screen away from the frame. You'd have to open up the phone and inspect the battery to be able to tell for sure.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
No it’s just laying on the frame perfectly flat it sticks up like a millimeter
door
@staxxbundles Have you replaced the screen, or is this happening with the original screen?
door
Voeg je antwoord toe
Staxx Bundles zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 96
