Ga door naar hoofdinhoud
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
422 Vragen Bekijk alle
Why my tray wont stay closed
I need help. My tray wont stay closed. It closes for like two secs and then opens right back up. Also theres a green blinking light that never stops blinking idk if that has something to do with it.
Is dit een goede vraag?
Score 16
11 opmerkingen
Does the CD drive shut all the way? Can you peer into the drive and see if the little "button" that detects when the tray shuts? Can you hear the drive motor straining even it is shut?
door
hey did you ever fix your xbox? because mine is doing the exact same thing as yours. and i dont know what to do? i need help!
door
Chris did you ever check out the site I recommended as one of the answers? You will find what you need to do there.
door
My Xbox 360 will not stay close I really need help asap
door
Hi, I also have the same problem. My disc tray won't open. I need to open it with a paper clip each time. And now it doesn't close properly. I have to press it when it closes until it reads the game. I had a other xbox 360 that "red eyed" so i took out the disk drive and put it in my one. But it does not ready my disks. Can someone help please.
door
6 commentaren meer tonen
Voeg een opmerking toe
9 Antwoorden
Het nuttigste antwoord
This from here "Debris in disc drive
If your disc drive tray is stuck and will not open or close, then you have to manually eject the disc. Follow these instructions to remove the faceplate and manually eject the drive. Remove any obstructions, and plug the console back in. If the eject button still doesn't work, your disc drive may need to be replaced."
In general, for any optical drive, you want to check the following:
Stuck disc or other object in drive
Remove the disc
If there is a disc in the tray remove it.
Disc drive button broke
Bad drive gears
there is also the possibility that your drive does not read the disk (try other ones) and therefore opens the tray. That would also be connected to the flashing green light, since it indicated that your drive is trying to read a disk. You might try to clean the laser of your drive, or think about replacing your drive. Just remember "The Xbox 360 is designed so that the DVD drive works only with the particular game console it is installed in. Replacing a defective DVD drive with a replacement DVD drive does not work, since the replacement has a different DVD drive key, which the game console won't accept. ...Hope this helps, good luck.
Was dit antwoord nuttig?
Score 3
The drive belt in the DVD is stretched out and dirty. Take the belt out of the drive, wash it thoroughly with hot water and dish soap. Pat it dry. Put in a microwave for 1 minute. That will shrink it back to the right size. While you have the drive open clean the wheels with rubbing alcohol using a q-tip. That should fix it.
Score 2
2 opmerkingen:
Thanks Dennis, Will try that and let you know.
If i have an other drive will flashing it help? and is that legal?
door
If you have the same model drive you are better off swapping the motherboards out. A chip on the motherboard is married to the CPU so flashing won't help.
door
My 360 was doing the same thing. I tried to unplug the power supply for a few minutes. It was still doing it. I often get the open disk problem too. Can't play my games anymore if I turn off the console. So I was a lil !#^&@@ off and smacked it and bam, problem solved my door closes now. Lol!! So I dunno what I did but worked for me... Still having problems with the games though...
Score 1
Check this site out. They will be able to help you there. My guess is you need a new drive but the site has fixes for all of the 360 stuff.
http://www.xbox-scene.com/
Head to the forums and ask your question and they will take care of you.
My x box 360 opens n close and opens n closes n don't stop till I unplug it how do I fix it ?
I need help my Xbox 360 wont stop opening and closing
turn it off wait for about 5 minutes turn it back on clean the inside of the tray or it needs repair
it probably needs repair or turn it of for 4 hours then turn it back on
The drive belt in the DVR player is dirty and it’s slipping. You need to remove it, wash it with soap and water and reinstall it.
Voeg je antwoord toe
Jaime Ybarra zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 22
Afgelopen 7 dagen: 101
Afgelopen 30 dagen: 450
Altijd: 56,180
