Ga door naar hoofdinhoud
The larger version of Samsung's flagship phone. Released March 2018.
129 Vragen Bekijk alle
How to open forgotten pattern
Forgate pattern and connect with wifi
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
If you don't care about the data you could hard reset the phone in this way it will clear everything. Of course you will need to re-enter your google email account and password to verify that the phone is yours.
Hard Reset for S9+
  1. Hold down the Power key + Volume Down for a few seconds to hard switch off/restart the mobile.
  2. Plug in cable to PC.
  3. In the second step start pressing Volume Up + Bixby + Power button for a couple of seconds.
  4. Let go of all buttons when the SAMSUNG logo appears.
  5. If you see Android Robot with "No command" tap on the screen.
  6. After that select "wipe data/factory reset" by using Volume buttons to navigate and the Power key to confirm that.
  7. In this mode choose "Yes -- delete all user data". Use Volume keys to scroll down and the Power button to accept it.
  8. Finally select "reboot system now" with the Power key.
Good Luck!
Was dit antwoord nuttig?
Voeg je antwoord toe
Fuad Ali zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 35
Altijd: 88
