Ga door naar hoofdinhoud
An Android smartphone announced by vivo, a Chinese technology company, in March 2018. Models: 1725, X21A.
12 Vragen Bekijk alle
Earphone's Micrphone not Working In my phone But In Other's?
Why My Earphone's Microphone not Working In my phone But Working In Other's?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
If your earphone's microphone is not working on your phone but is working on other devices, there could be several reasons for this discrepancy. Here are some troubleshooting steps to help you identify and potentially resolve the issue:
  1. Check Compatibility: Ensure that your earphones are fully compatible with your phone. Some earphones might have compatibility issues with certain phone models.
  2. Clean the Jack: Sometimes, dirt or debris can accumulate in the headphone jack, affecting the connection. Carefully clean the jack using a small brush or compressed air.
  3. Check Settings: Make sure that your phone's audio settings are properly configured to use the earphone's microphone. Check both the system settings and any app-specific settings that you are trying to use the microphone with.
  4. Test with Different Apps: Try using the microphone with different apps that require audio input. This will help you determine whether the issue is specific to one app or a broader system issue.
  5. Restart Your Phone: A simple restart can often resolve minor software glitches that might be causing the microphone issue.
  6. Check for Software Updates: Ensure that your phone's operating system and apps are up to date. Sometimes, compatibility issues can be resolved with software updates.
  7. Test with Another Pair of Earphones: To rule out any issues with the earphones themselves, try using a different pair of earphones with a microphone on your phone. If the alternate earphones work, the problem might be with your original pair.
  8. Check for Physical Damage: Inspect both the earphone's connector and your phone's headphone jack for any physical damage. Bent or damaged connectors might not establish a proper connection.
  9. Reset Audio Settings: If there are any customized audio settings that might be causing the issue, you can try resetting your phone's audio settings to default.
  10. Safe Mode: Boot your phone into Safe Mode to see if a third-party app is causing the issue. If the microphone works in Safe Mode, then a downloaded app might be interfering with the microphone function.
  11. Contact Support: If none of the above steps work, it's a good idea to contact your phone's manufacturer or customer support for assistance. They might have more specific troubleshooting steps for your device.
Remember that the issue could be a combination of hardware and software factors, so it might take some trial and error to pinpoint the exact cause.
Was dit antwoord nuttig?
Voeg je antwoord toe
Yogesh Singh Rawat zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 108
