Ga door naar hoofdinhoud
Mid 2006 / model number A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor.
507 Vragen Bekijk alle
Top Case v3 (922-8265) on MacBook 1,1 is that possible?
MacBook Santa Rosa/Penryn Upper Case with Keyboard
I saw this Macbook part. I own a Macbook, the 2006 model, Macbook Core Duo A1181 (last 4 # of serial are: RVMN).
I saw this top case: however, a "techie" told me that the cable is different, and it won't fit on my Logic Board, because while my original topcase had a single connector, this one should have a cable with two ribbons.
Would the 922-8265 Top Case be fine on my old laptop? Eventually, may I transplant the cable from my old top case to the new one?
MacBook Santa Rosa/Penryn Upper Case with Keyboard Afbeelding
Product
$119.99
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Yes. Any of these top cases will work for you: Apple Part #: 922-9550, 922-8264, 922-8265, 661-5075, 661-5076
The part number you gave is for a black topcase. I have not seen this one with two cables, maybe your techie friend has been smoking something that makes him see double.
Was dit antwoord nuttig?
Score 5
Commentaar:
So I'll get a 922-8265 as soon as I manage to get one. I took the black topcase number because... my 1,1 Macbook is black.
Then, I guess I'd just have it fitted. Thank you for your swift reply.
door
Voeg je antwoord toe
Stefano Gigante zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,466
