Ga door naar hoofdinhoud
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
431 Vragen Bekijk alle
Help with RAM upgrade?
I need to upgrade the RAM in my iMac. It is either an EMC 2134 or 2211, but I don't know which. I need help figuring it out. here are my system specs:
2.8GHz Intel Core 2 Duo
2 (1GBx2) GB 800 MHz DDR2 SDRAM
L2 Cache: 6MB
Bus: 1.07GHz
SMC Version 1.30f1
OPTIARC DVD RW AD-5630A
ATI Raedon HD 2600 Pro 256MB
WDC WD3200AAJS-40VWA1 320GB
I am currently running snow leopard with no problems. Again, can anyone figure out whether this is a EMC 2134 or 2211? Thanks.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
in Apple parlance, your iMac 2.8GHz Core 2 Duo with 1066MHz system bus would be AKA an iMac 24" (Early 2008) model
this iMac has 2 memory slots and according to Mactracker it can support up to 6GB of RAM, 200pin PC2-6400 (800MHz) DDR2 SO-DIMM (support for up to 6GB in this model is confirmed by other sources, even though Apple's official spec is 4GB)
note: the iMac 24" (Mid 2007) model has a slower system bus 800MHz, has only 4MB L2 cache, and only supports up to 4GB of PC2-5300 DDR2 RAM). So it seems your iMac is the Early 2008 variant I mentioned earlier.
BTW, you should be able to find the EMC number on the bottom of the stand of your iMac
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Mark zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 4,561
