Ga door naar hoofdinhoud
Elektrische waterkoker met digitale temperatuurregeling.
The switch for temperature units is broken and doesn't go from F to C
Same as title. Switch gives no feedback. Can't go back to Celsius. I have tried unplugging and plugging back in but to no avail!
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
I bought a broken unit that pleasantly came with an extra kettle, which presumably works.
I want to use the part from the bought but tattered unit to replace the part in the original base, but am trying to figure out how to pry the base open. I'm waiting to hear from someone who did successfully to figure out how to do it.
It's stuck on F because there's a board with a button that goes to C when the button is covered. You have a bad board/button and need a new one. I'll let you know how this goes as I make progress. I also took pics of the part board to show you what's going on and how it looks from the inside.
The switch is a Kailh switch, which is a cheap Chinese part that's made to break. This is just poor part quality.
Afbeelding
Afbeelding
Afbeelding
Was dit antwoord nuttig?
Score 2
1 Opmerking:
did you ever figure out how to prise the base apart?
door
Voeg je antwoord toe
Ian Zeringue zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 46
Altijd: 1,150
