Ga door naar hoofdinhoud
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117 Vragen Bekijk alle
Can I Use a Keyboard from an iBook G4 12" in Here?
so i have had my iBook G3 for a while, the keyboard sucks, though. it has the spongy effect, and after doing some research, i read that the keyboards from iBook G4's are much better, I was wondering if i could buy an ibook g4 keyboard and put it in my G3 with no problem, do they use the same connector? is the cable the same form? thanks in advance.
Also, I have an 800Mhz Model A1005
Is dit een goede vraag?
Score 2
1 Opmerking
it is the solid white laptop, not the silver/clear one, not the clamshell either
door
Voeg een opmerking toe
7 Antwoorden
Gekozen oplossing
My daughter didn't like her iBook G4 12" 1.33Ghz keyboard so I installed a iBook G3 12" 800mhz keyboard on the 1.33 G4 and it worked great. Connector was the same, no fitting, it was a very simple swap. I think all iBooks G3 dual USB (not the clamshell) and the iBook G4 have the same keyboard connector. You can even fit a 14" keyboard in a 12" case but you'll have to fold the cable a little under the keyboard.
Was dit antwoord nuttig?
Score 5
2 opmerkingen:
Clearly you have experience with this matter but I'm afraid I disagree. Student IT has fixed around 20-40 iBooks without ordering any parts (sacrificing two broken ones to make one working one) and due to this method of use-what-you-have I distinctly remember trying to mix and match keyboards between the two versions and the connector of the G4 being smaller than in the G3.
Perhaps someone else could suggest their opinion in this matter?
door
QEII Student IT, please look at my other answer. You'll see a iBook G3 keyboard connected in a iBook G4 logic board. It connects perfectly and full working on my daughter iBook G4 1.33Ghz
door
OK QEII Student IT so check this link and this pict:
http://www.flickr.com/photos/61008642@N0...
Score 3
4 opmerkingen:
Ok, thanks for clarifying anyways
door
Just confirmed that lemerise is right on this one. I've found it wise not to disagree with lemerise, especially within the realm of iBooks! :)
door
Ah Ah...Ben you're the expert here not me !! ;-)
door
Thanks for the clarification on this guys, I have removed my answer to avoid confusion.
door
the iBook G3 12" keyboard does work and fit in the iBook G4 12" but the keyboard cable for the iBook G4 12" is shorter so you can't fit a G4 12" keyboard in an iBook G3 12".
You can, however, fit an iBook G4 14" keyboard in an iBook G3 12".
Will a ibook G4 12" keyboard fit inside a ibook G4 14"?
1 Opmerking:
no, ribbon cable will be too short.
door
Can you used a ibook g3 keyboard in a ibook g4 14 inch?
1 Opmerking:
iBook G3 14" keyboard should fit in a iBook G4 14"
door
Will an iBook G4 14" Keyboard fit into a 14" G3 iBook?
1 Opmerking:
I'd like to know the answer to this too..
door
One thing that you can do is take the keys and the assembly from the G4 and install it on the G3 keyboard which would probably make it feel like a G4.
1 Opmerking:
I would not count on it. There are at least four differents key mechanisms in the ibook G4 line and they could not fit with the iBook G3 keyboard key mechanisms even if you can swap the complete keyboard between the G3s and the G4s.
door
Voeg je antwoord toe
Chris Green zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 5,446
