Ga door naar hoofdinhoud
Model A1040 / 10, 15, 20, 30, or 40 GB hard drive / four touch-sensitive LED backlit buttons above touch wheel
107 Vragen Bekijk alle
upgrade hard drive from 15GB to 40GB
Can I upgrade the hard drive in my iPod 3rd generation (model A1040) with 15GB to 40GB? Do I need to replace the back cover or anything else?
Thanks in advance.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
ddo, the 3rd Generation iPods can use any of the 10, 15, 20, 30 and 40GB Toshiba pin type 1.8" drives that end in 004, such as MK2004GAL. The 30 and 40GB drives require deeper back plates. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 2
That doesn't quite answer the question. Will a 40GB drive fit into a 15GB case?
Commentaar:
Not sure what it did not answer "30 and 40GB drives require deeper back plates"
door
Voeg je antwoord toe
ddo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,002
