Repaired slide lock, now console won't recognize joy-con when attached
I recently used this website to fix the locks inside the right joy-con so it wouldn't just slide off when in use. While doing so, the gold banded wires with the small, slide clip on the end (don't know the technical term, sry) both detached from the main body of the joycon.
I was able to get the bottom-most one reinserted and fussed with the other for an hour before realizing I could remove the battery and the housing and insert it more easily. In reconnecting that, the gold-banded wire at the top of the controller that connects to the battery housing disconnected, so I reconnected it, too.
Now the system recognizes the right joy-con as having been taken off the main unit, but not as part of the unit when slotted in. How can I fix this?
Is dit een goede vraag?
1 Opmerking
Can you add some pictures of these "gold banded wires with the small, slide clip on the end"? I think I know what you mean, but it'll help to have pictures
door darth mango
