Ga door naar hoofdinhoud
The 2012 Ford Fusion is a midsize sedan that is part of the second iteration of the first generation originally released by Ford in 2006.
How can I change an air bag?
I would like to know if the steering wheel radio cable connecter can get affected by an airbag replacement
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@pelancharamos I am not a big fan of replacing these but if you have to replace it, use something like this video. Replacing the airbag should not affect the radio cable connector. It all depends who works on it and how well somebody works on it :-)
Was dit antwoord nuttig?
Score 2
1 Opmerking:
The answer to "How do you replace an airbag" is the same as the answer to the question, "How do you pick up a porcupine".
In both cases the answer is: Very Carefully
door
Voeg je antwoord toe
Pelancha Ramos zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 142
