Ga door naar hoofdinhoud
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
83 Vragen Bekijk alle
Right 1/3 of screen shows vertical video noise,
My 24" LED Cinema Display is showing of the right third of the screen patches of colour, sometimes video noise, lines, etc. But just the right third. What could be the problem?
Here is the monitor in action:
Video
http://www.surettephotography.ca/Surette...
Pictures:
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
This can either be a bad LCD, or a bad LVDS cable going from the display to the driver board. In some cases, the controller board will be at fault.
First thing to check is the cable - source out a cable, swap it out and see if the issue gets resolved. If it does not, then you’re sadly looking at an expensive repair :-(. Either you’ll need to replace the LCD ($$$ due to LG panel cost), or the driver board ($$ so not as bad but still expensive. As far as parts go, check sites like eBay as well as scrappers who resell the parts from these.
The issue with repairing these beyond a new LVDS cable is the parts cost will more or less rival a used replacement, or a Thunderbolt upgrade on capable Macs.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
paulsurette71 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 694
