Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor camera's van Blink. Videobeveiligingscamera voor thuis met batterijen die tot twee jaar meegaan. Modellen: Blink, Blink XT2, Blink Indoor, Blink Outdoor, Blink Mini
Outdoor camera full of rain water
My blink outdoor filled up with rain. How can I open it up to dry it out and clean the inside of the lens?
Is dit een goede vraag?
Score 3
1 Opmerking
If this was placed without shielding from rain falling directly on it, it's probably not water proof. Even weather proof devices can collect water and debris. Some devices with replaceable batteries may allow disassembly with screws hidden under labeling. Probing with a small tipped screwdriver pressed onto labeling may reveal a hidden screw hole(s). Others are heat sealed and not meant for repairs.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I solved this problem with a camera pointed mostly down. While I was not able to open it to clean the moisture out, I did take the back cover off and place it in front of a fan. Which dried it out after 5 hours. As far as keeping it from happening again I just covered the back with Duct tape. Problem solved
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Worked perfectly…I thought I would have to pay for a new one.Thank you so much.
door
Voeg je antwoord toe
Big Bird zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 70
Altijd: 5,550
