Ga door naar hoofdinhoud
Repair guides and support for Panasonic's Viera line of televisions.
405 Vragen Bekijk alle
Top Half screen is black after watching for a while
My panasonic viera p60s60 also has this problem ( Why is my panasonic viera plasma tv have half screen black ) starting few days ago. Top Half screen is black after watching for a while and sometimes picture comes back or after power off for a day. So i think board may not failed. May be connector just gets dirty because tv is 10 years old.
But problem is i live alone. So it is very difficult to place tv face down. If just removing back panel, is it possible to do vertically?
Is dit een goede vraag?
1 Opmerking
The problem comes back. Now even after cleaning or reseating cable/connectors, does not help.
But sometimes, only sometimes picture is displayed.
I decided to order part form ebay, the used SU board.
And it appears even after changing SU hoard, that the problem still exists. Only sometimes picture is displayed for a while. But mostly it is black.
Should it be SC board problem?. I don't see any swollen capacitor.
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
@aeykung it is only possible if you can get the back cover off without having to remove the stand. On some Panasonic's it is okay to leave the stand on. Your stand should have a little plastic cap where it mounts to the TV. Remove that and see if you have enough clearance to remove the back cover.
Was dit antwoord nuttig?
Score 1
Thank you. I can remove back panel while stand is installed to TV.
TV is now working already.
my first assumption is that boards may not fail because upper screen is black randomly.
maybe dirt or oxidation on some cables or connectors.
and after clean and test one by one, the problem is ribbon cable connecting SU and SD board. after clean that one, no black screen anymore.
Voeg je antwoord toe
aeykung zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 29
