Ga door naar hoofdinhoud
The Wacom Intuos Pro is a graphic design tablet designed by Wacom. The device comes with, a type-C charger, the Pro pen 2, and the Pen holder.
7 Vragen Bekijk alle
Removing battery for USB only usage?
Is possible to simply remove the battery inside PTH-660? In a studio setup, it is not really needed. USB is better!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
You can remove the battery but you'll need a soldering iron. You can follow this ifixit guide here.
Was dit antwoord nuttig?
OK, thanks, but removing the battery puts the tablet in "USB Only" mode?
Nevermind the question.
I removed the battery and I can confirm: the tablet Works Without the battery. Just a brief message that the battery il low, but after that IT WORKS
Voeg je antwoord toe
Luca Di Meo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 126
