Ga door naar hoofdinhoud
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
548 Vragen Bekijk alle
Is this the right logic board for late 2015 iMac 27”
Purchased this from eBay to replaced the faulty logic board on my 27” iMac late 2015, but it looks like it is different layout on GPU compared with the original board I have, also, the component circled in red was off, can any one advise this is the right board? And that missing component won’t harmful for the whole system at all? Just want to check it before installing it.
Many thanks.
Is dit een goede vraag?
Score 1
3 opmerkingen
@lovecd do you have teh 820-xxxx numbers for both boards? That way we can check on what you got there.
door
Where should that number be printed?
door
should be on the board. Sometimes those are hard to see since they are more of an imprint than a print. looks like yours should be a 820-00292
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@lovecd the parts missing are:
CA640 and it is a 470uF 20% 2V capacitor in a D2 package
LA630 which is a 2.2uH 10A inductor in a IHLP2525EZ package
Both parts are critical for your GPU circuitry. You do not want to use this board. Return it since it was used to harvest parts off it.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thank you so much! @oldturkey03
door
Voeg je antwoord toe
Tom zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 37
