Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Vragen Bekijk alle
what's that piece? (picture inside)
hey guys,
i replaced my dispay and when i removed the vibrator this thing suddenly popped out. it feels like rubber. i got no idea where its coming from. but everything works finde, except for the light sensor! (display doesnt turn black when i call someone)
any ideas? thanks in advance! heres the picture:
http://imageshack.us/photo/my-images/851...
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
That part is the rubber bumper that fits on the top edge of the logic board. It goes under the two front screen flex cables as they bend around (over) the top of the logic board. It is not a critical component for the iPhone to function. It is not the reason for the Proximity Sensor failure. That is due to bad front screen glass or due to not separating sensor in/out beams correctly. When you decide to correct the sensor problem, you can easily replace the rubber bumper.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
thanks a lot! but what exactly do you mean by "separating sensor in/out beam" ?
door
the sensor needs to be able to sense when you have the glass to your face or not. Some screens have no way of separating in or out beams..this can be fixed with a piece of tape with holes cut in it placed over the glass in the area where the sensors are...
door
Voeg je antwoord toe
victor zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 289
